公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5.1k粉丝
--- 产品详情 ---
适用于 USB 2.0 且具有 1nA 最大泄漏电流和 VCC 引脚的双路 1.5pF、5.5V、±8kV ESD 保护二极管
Number of channels (#) 2
IO capacitance (Typ) (pF) 1.5
Vrwm (V) 5.5
IEC 61000-4-2 contact (+/- kV) 8
Bi-/uni-directional Uni-Directional
Dynamic resistance (Typ) (?) 1.2
Clamping voltage (V) 25
IO leakage current (Max) (nA) 1
Rating Catalog
Operating temperature range (C) -40 to 85
  • IEC 61000-4-2 ESD Protection (Level 4)
    • ±8-kV Contact Discharge
    • ±15-kV Air-Gap Discharge
  • IO Capacitance: 1.5 pF (Typ)
  • Low Leakage Current: 1 nA (Maximum)
  • Low Supply Current: 1 nA
  • 0.9 V to 5.5 V Supply-Voltage Range
  • Space-Saving DRL, DRY, and QFN Package Options
  • Alternate 3, 4, 6-Channel options Available:
    TPD3E001, TPD4E001, TPD6E001
The TPD2E001 is a two-channel Transient Voltage Suppressor (TVS) based Electrostatic Discharge (ESD) protection diode array. The TPD2E001 is rated to dissipate ESD strikes at the maximum level specified in the IEC 61000-4-2 Level 4 international standard.
The DRS package (3.00 mm × 3.00 mm) is also available as a non-magnetic package for medical imaging applications.
See also TPD2E2U06DRLR which is p2p compatible to TPD2E001DRLR and offers higher IEC ESD Protection, lower clamping voltage, and eliminates the input capacitor requirement.
