公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5.1k粉丝
--- 产品详情 ---
4.25Gbps 8 通道转接驱动器
Type Redriver
Number of channels (#) 8
Input compatibility CML, AC-coupling, LVPEC
Speed (Max) (Gbps) 4.25
Protocols XAUI
Operating temperature range (C) -40 to 85
  • 8 Input and 8 Output Signal Conditioning Buffer
  • Up to 4.25 Gbps Operation
  • 30 ps of Deterministic Jitter
  • Selectable Transmit Pre-Emphasis Per Lane
  • Selectable Receive Equalization
  • Available Packaging 64 Pin QFP
  • Propagation Delay Times: 400 ps Typical
  • Inputs Electrically Compatible With CML Signal Levels
  • Operates From a Single 3.3-V Supply
  • Ability to 3-State Outputs
  • Integrated Termination Resistors
  • I2C Control Interface
The SN65LVCP418 is an 8 Channel signal conditioning buffer in a flow-through pin-out allowing for ease in PCB layout. VML signaling is used to achieve a high-speed data throughput while using low power. Internal signal paths are fully differential to achieve the high signaling speeds while maintaining low signal skews. The SN65LVCP418 incorporates 100-Ω termination resistors for those applications where board space is a premium. Built-in transmit pre-emphasis and receive equalization for superior signal integrity performance.
The SN65LVCP418 is characterized for operation from –40°C to 85°C.
