公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5.1k粉丝
--- 产品详情 ---
具有光纤和 AUI 支持的 10/100Mbps 以太网 PHY 收发器
Datarate (Mbps) 10/100
Interface type MII, SNI
Number of ports Single
Rating Catalog
Features FX support, AUI support
Supply voltage (V) 5
IO supply (Typ) (V) 5
Operating temperature range (C) 0 to 70
  • IEEE 802.3 ENDEC with AUI/10BASE-T transceivers
    and built-in filters
  • IEEE 802.3u 100BASE-TX compatible - directly drives
    standard Category 5 UTP, no need for external
    100BASE-TX transceiver
  • Fully Integrated and fully compliant ANSI X3.263 TPPMD
    physical sublayer which includes adaptive equalization
    and BLW compensation
  • IEEE 802.3u 100BASE-FX compatible - connects directly
    to industry standard Electrical/Optical transceivers
  • IEEE 802.3u Auto-Negotiation for automatic speed selection
  • IEEE 802.3u compatible Media Independent Interface
    (MII) with Serial Management Interface
  • Integrated high performance 100 Mb/s clock recovery
    circuitry requiring no external filters
  • Full Duplex support for 10 and 100 Mb/s data rates
  • MII Serial 10 Mb/s mode
  • Fully configurable node/switch and 100Mb/s repeater
    modes
  • Programmable loopback modes for flexible systemdiagnostics
  • Flexible LED support
  • Single register access to complete PHY status
  • MDIO interrupt support
  • Individualized scrambler seed for 100BASE-TX applications
    using multiple PHYs
  • Low power consumption for multi-port applications
  • Small footprint 80-pin PQFP package
The DP83843BVJE is a full feature Physical Layer device with integrated PMD sublayers to support both 10BASE-T and 100BASE-X Ethernet protocols.
This VLSI device is designed for easy implementation of 10/100 Mb/s Ethernet LANs. It interfaces directly to Twisted Pair media through an external transformer or to fiber media via industry standard electrical/optical fiber PMD transceivers. This device also interfaces directly to the MAC layer through the IEEE 802.3u standard Media Independent Interface (MII), ensuring interoperability between products from different vendors.
The DP83843 is designed with National Semiconductor?s advanced CMOS process. Its system architecture is based on the integration of several of National's industry proven core technologies:
  • IEEE 802.3 ENDEC with AUI/10BASE-T transceiver module to provide the 10 Mb/s functions
  • Clock Recovery/Generator Modules fromNational's Fast Ethernet and FDDI products
  • FDDI Stream Cipher scrambler/descrambler for TP-PMD
  • 100BASE-Xphysical codingsub-layer (PCS) andcontrol logic that integrates the core modules into a dual speed Ethernet physical layer controller
  • ANSI X3T12 Compliant TP-PMD Transceiver technology with Baseline Wander (BLW) compensation
