公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5.1k粉丝
--- 产品详情 ---
Type-C USB 3.2 交替模式转接驱动器/多路复用器
Function Type-C
Type Active mux
Alternate mode Yes
External power path control No
Data role DFP
USB speed (Mbps) 10000
Rating Catalog
Operating temperature range (C) 0 to 70, -40 to 85
  • USB Type-C crosspoint switch supporting
    • USB 3.2 SSP + 2 DisplayPort Lanes
    • 4 DisplayPort Lanes
  • USB 3.2 x1 Gen 1/Gen 2 up to 10 Gbps
  • VESA?DisplayPort 2.0 up to 10 Gbps (UHBR10)
  • Supports D_DFP pin assignments C, D, and E
  • Choice between adaptive or fixed equalization for USB DFP receivers.
  • Linear and limited redriver supported on UFP transmitter
  • Limited redriver option offers both TX voltage swing and TX equalization control
    • 4 Levels of TX voltage swing from 800 mVpp up to 1100 mVpp
    • TX pre-shoot and de-emphasis
  • Ultra-low-power architecture
  • Up to 12 dB equalization at 5 GHz
  • Transparent to DisplayPort link training
  • Configuration through GPIO or I2C
  • Intel proprietary DCI capability on USB Type-C for closed chassis debugging
  • Hot-Plug capable
  • Industrial temperature range: –40 oC to 85 oC (TUSB1146I)
  • Commercial temperature range: 0 oC to 70 oC (TUSB1146)
  • 4 mm x 6 mm, 0.4 mm Pitch WQFN package
The TUSB1146 is a VESA USB Type-C? Alt Mode redriving switch supporting USB 3.2 data rates up to 10 Gbps and DisplayPort 2.0 up to 10 Gbps for downstream facing port (Host). The device is used for configurations C, D, and E from the VESA DisplayPort Alt Mode on USB Type-C standard. This protocol-agnostic linear redriver is also capable of supporting other USB Type-C Alt Mode interfaces such as HDMI Alt Mode.
The TUSB1146 incorporates an innovative, adaptive receiver equalization (AEQ) feature. The AEQ feature will automatically find the best ISI compensation setting between the USB device and the TUSB1146. Because the AEQ finds the best setting, interoperability between a USB Host and USB Device is vastly improved. The TUSB1146 operates on a single 3.3-V supply and comes in a commercial temperature range and industrial temperature range.
