公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5.1k粉丝
--- 产品详情 ---
具有直流升压、集成式 CDP、宽电源和直通封装的 USB 2.0 高速信号调节器
Type Redriver
Function USB2
USB speed (Mbps) 480
Number of channels (#) 1
Supply voltage (Max) (V) 6.5
Supply voltage (Min) (V) 2.3
Input/ouput voltage (Min) (V) 0
Input/ouput voltage (Max) (V) 3.6
Configuration USB 2.0 Single-channel
Features USB 2.0 high-speed signal conditioning , Compatible with USB 2.0, OTG 2.0 and BC 1.2
Rating Catalog
Operating temperature range (C) 0 to 70
ICC (Max) (uA) 36mA
ESD HBM (Typ) (kV) 2
Bandwidth (MHz) 240
  • Wide supply voltage range: 2.3 - 6.5 V
  • Ultra-low USB disconnect and shutdown power consumption
  • Provides USB 2.0 high-speed signal conditioning
  • Compatible with USB 2.0, OTG 2.0 and BC 1.2
  • Support for low-speed, full-speed, high-speed signaling
  • Integrated BC 1.2 CDP battery charging controller
  • Host/Device agnostic
  • Supports up to 5-m cable length
    • Four selectable signal boost (edge boost along with DC boost) settings via external pull-down resistor values
    • Three selectable RX sensitivity settings via pull-up-or-down to compensate ISI jitter for high-loss applications
  • Supports up to 10-m cable length with two TUSB216 devices
  • Scalable solution - devices can be daisy chained for high loss applications
  • Pin compatible with TUSB211/212/214 (3.3V)
The TUSB216 is a third-generation USB 2.0 high-speed signal conditioner designed to compensate both AC loss (due to capacitive load) and DC loss (due to resistive loss) in the transmission channel.
The TUSB216 leverages a patented design to speed-up transition edges of USB 2.0 high-speed signal with an edge booster and increases static levels with a DC boost function. In addition, the TUSB216 includes a pre-equalization function to improve the receiver sensitivity and compensate the inter-symbol interference (ISI) jitter in application with longer cable length. USB low-speed and full-speed signal characteristics are unaffected by the TUSB216.
The TUSB216 improves signal quality without altering packet timing or adding propagation delay or latency.
The TUSB216 helps a system to pass the USB 2.0 high-speed near end eye compliance with a cable as long as 5 meters.
The TUSB216 is compatible with the USB On-The-Go (OTG) and battery charging (BC 1.2) protocols. The Integrated BC 1.2 battery charging controller can be enabled via a control pin.
