公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5.1k粉丝
--- 产品详情 ---
USB 2.0-eUSB2 双路中继器
Type Redriver
Function USB2
USB speed (Mbps) 480
Number of channels (#) 2
Supply voltage (Max) (V) 1.98, 3.6
Supply voltage (Min) (V) 1.62, 3
Input/ouput voltage (Min) (V) 0
Input/ouput voltage (Max) (V) 3.6
Configuration Dual-channel
Features implementation of USB 2.0 and eUSB2 compliance port Support for Low-speed (LS), Full-speed (FS), High-speed (HS) signals
Rating Catalog
Operating temperature range (C) -20 to 85
ESD HBM (Typ) (kV) 1.5
Bandwidth (MHz) 240
  • Compliance to USB 2.0 and eUSB2 (rev 1.1)
  • Support for Low-speed (LS), Full-speed (FS), High-speed (HS)
  • Dual repeater with 2:2 crossbar Mux
  • Host and device mode (DRD) support
  • 4 eUSB2 compensation settings to meet different system requirements
  • eUSB2 LS/FS signaling meets 1.2 V option of the eUSB2 interface
TUSB2E22 enables implementation of USB 2.0 compliance port on newer processors using lower voltage processes.
TUSB2E22 is a USB-Compliant eUSB2-USB 2.0 repeater supporting both device and host modes.
TUSB2E22 supports USB Low-speed (LS) and Full-speed (FS) signals and High-speed (HS) signals.
TUSB2E22 is designed to interface with eUSB2 eDSPr or eUSPr operating at 1.2 V single-ended signaling.
TUSB2E22 has 4 levels of compensation settings via EQ0 and EQ1 pins. These settings could be used to optimize compensation for different eUSB2 channel loss profiles.
