公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5.1k粉丝
--- 产品详情 ---
带集成 5V 负载开关且适用于 USB-PD 设备的双 USB 告示板
Function USB2
Type Passive switch
External power path control No
Internal power path 5 V 3 A
USB speed (Mbps) 480
Rating Catalog
Operating temperature range (C) -10 to 85
  • Port-power switch
    • 5-V, 3-A integrated switch to VBUS
    • Over-current limiter, over-voltage protector
    • Slew-rate control
  • USB low-speed endpoint
    • I2C-update capable billboard strings
    • Integrated USB mux supports two Type-C ports
    • I2C control
  • Power management
    • Power supply from 3.3-V
  • NFBGA package
    • 0.5-mm pitch
    • Through-hole via compatible for all pins
The TPS65982BB device provides a USB billboard endpoint for USB-PD devices implementing alternate modes. The integrated internal USB multiplexor allows the TPS65982BB to support up to two USB Type-C ports. The TPS65982BB communicates with USB-PD port controllers using an I2C interface to enable the billboard as well as update stored billboard strings. An integrated 5-V load switch provides VBUS protection for an optional USB Type-A port.
