公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
±10V 输入、电压检测隔离式放大器
Device type Voltage sensing
Input range (Vp-p) ±10
Isolation working voltage VIOWM (rms) (V) 1500
Input offset (+/-) (Max) (mV) 50
Input offset drift (+/-) (Typ) (uV/C) 200
Gain error (+/-) (Max) (%) 0.5
Gain error drift (+/-) (Typ) (ppm/°C) 10
Gain non-linearity (+/-) (Max) (%) 0.02
Small signal bandwidth (Typ) (kHz) 50
Rating Catalog
Operating temperature range (C) -25 to 85
  • 100% Tested for High-Voltage Breakdown
  • Rated 1500 Vrms
  • High IMR: 140 dB at 60 Hz
  • Bipolar Operation: VO = ±10 V
  • 16-Pin Plastic DIP and 28-Lead SOIC
  • Ease of Use: Fixed Unity Gain Configuration
  • 0.020% Maximum Nonlinearity
  • ±4.5-V to ±18-V Supply Range
The ISO122 is a precision isolation amplifier incorporating a novel duty cycle modulation-demodulation technique. The signal is transmitted digitally across a 2-pF differential capacitive barrier. With digital modulation the barrier characteristics do not affect signal integrity, thus resulting in excellent reliability and good high-frequency transient immunity across the barrier. Both barrier capacitors are imbedded in the plastic body of the package.
The ISO122 is easy to use. No external components are required for operation. The key specifications are 0.020% maximum nonlinearity, 50-kHz signal bandwidth, and 200-V/°C VOS drift. A power supply range of 4.5 V to 18 V and quiescent currents of 5 mA on VS1 and ±5.5 mA on VS2 make the ISO122 ideal for a wide range of applications.
The ISO122 is available in 16-pin plastic DIP and
28-lead plastic surface-mount packages.
