公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5.1k粉丝
--- 产品详情 ---
具有可调阈值和锁存功能的汽车类快速响应基础型隔离式比较器
Number of channels (#) 1
Output type Open-drain
Propagation delay time (μs) 0.24
CMTI (Min) (kV/μs) 55
Operating temperature range (C) -40 to 125
Rating Automotive
  • AEC-Q100 qualified for automotive applications:
    • Temperature grade 1: –40°C to +125°C, TA
  • Wide high-side supply range: 3 V to 25 V
  • Low-side supply range: 2.7 V to 5.5 V
  • Adjustable threshold: 20 mV to 2.7 V
  • Reference current for threshold adjustment:
    • 100 μA, ±1%
  • Trip threshold error: ±1% (max) at 250 mV
  • Open-drain output with optional latch mode
  • Propagation delay: 240 ns (typ)
  • High CMTI: 75 V/ns (min)
  • Safety-related certifications:
    • 4250-VPK basic isolation per DIN EN IEC 60747-17 (VDE 0884-17)
    • 3000-VRMS isolation for 1 minute per UL1577
The AMC22C11-Q1 is an isolated comparator with a short response time. The open-drain output is separated from the input circuitry by an isolation barrier that is highly resistant to magnetic interference. This barrier is certified to provide galvanic isolation of up to 3 kVRMS according to DIN EN IEC 60747-17 (VDE 0884-17) and UL1577, and supports a working voltage of up to 560 VRMS.
The trip threshold is adjustable from 20 mV to 450?mV in low-hysteresis mode and from 600 mV to 2.7?V in high-hysteresis mode through a single external resistor.
The open-drain output on the device supports transparent mode (LATCH input tied to GND2) where the output follows the input state, or latch mode, where the output is cleared on the falling edge of the latch input signal.
The AMC22C11-Q1 is available in an 8-pin SOIC package and is specified over the full automotive temperature range of –40°C to +125°C.
