Number of channels (#) | 2 |
Technology Family | AUC |
Supply voltage (Min) (V) | 0.8 |
Supply voltage (Max) (V) | 2.7 |
Input type | Standard CMOS |
Output type | Push-Pull |
Clock Frequency (Max) (MHz) | 275 |
IOL (Max) (mA) | 9 |
IOH (Max) (mA) | -9 |
ICC (Max) (uA) | 10 |
Features | Balanced outputs, Ultra high speed (tpd <5ns), Over-voltage tolerant inputs, Partial power down (Ioff) |
- Available in the Texas Instruments NanoFree? Package
- Optimized for 1.8-V Operation and Is 3.6-V I/O Tolerant to Support Mixed-Mode Signal Operation
- Ioff Supports Partial-Power-Down Mode Operation
- Sub-1-V Operable
- Max tpd of 1.9 ns at 1.8 V
- Low Power Consumption, 10-μA Max ICC
- ±8-mA Output Drive at 1.8 V
- Latch-Up Performance Exceeds 100 mA Per
JESD 78, Class II - ESD Protection Exceeds JESD 22
- 2000-V Human-Body Model (A114-A)
- 200-V Machine Model (A115-A)
- 1000-V Charged-Device Model (C101)
NanoFree is a trademark of Texas Instruments.
This dual positive-edge-triggered D-type flip-flop is operational at 0.8-V to 2.7-V VCC, but is designed specifically for 1.65-V to 1.95-V VCC operation.
When data at the data (D) input meets the setup time requirement, the data is transferred to the Q output on the positive-going edge of the clock pulse. Clock triggering occurs at a voltage level and is not related directly to the rise time of the clock pulse. Following the hold-time interval, data at the D input can be changed without affecting the levels at the outputs.
NanoFree? package technology is a major breakthrough in IC packaging concepts, using the die as the package.
This device is fully specified for partial-power-down applications using Ioff. The Ioff circuitry disables the outputs, preventing damaging current backflow through the device when it is powered down.
