Function | Counter |
Bits (#) | 10 |
Technology Family | HC |
Supply voltage (Min) (V) | 2 |
Supply voltage (Max) (V) | 6 |
Input type | Standard CMOS |
Output type | Push-Pull |
Features | Balanced outputs, High speed (tpd 10-50ns), Positive input clamp diode |
- 2-V to 6-V Operation
- Fully Static Operation
- Buffered Inputs
- Common Reset
- Positive-Edge Clocking
- Balanced Propagation Delay and Transition Times
- High Noise Immunity: NIL = 30%, NIH = 30% of VCC at VCC = 5 V
- Packaged in Ceramic (F) DIP Package and Also Available in Chip Form (H)
The CD54HC4017 is a high-speed silicon-gate CMOS 5-stage Johnson counter with ten decoded outputs. Each decoded output normally is low and sequentially goes high on the low-to-high transition of the clock (CP) input. Each output stays high for one clock period of the ten-clock-period cycle. The terminal count (TC) output transitions low to high after output ten (9) goes low, and can be used in conjunction with the clock enable (CE\) input to cascade several stages. CE\ disables counting when in the high state. The master reset (MR) input, when taken high, sets all the decoded outputs, except 0, to low.
The CD54HC4017 is characterized for operation over the full military temperature range of -55°C to 125°C.
