公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
具有输出寄存器的 8 位移位寄存器
Configuration Serial-in, Parallel-out
Bits (#) 8
Technology Family AHCT
Supply voltage (Min) (V) 4.5
Supply voltage (Max) (V) 5.5
Input type TTL-Compatible CMOS
Output type Push-Pull
Clock Frequency (MHz) 115
IOL (Max) (mA) 8
IOH (Max) (mA) -8
ICC (Max) (uA) 20
Features Balanced outputs, Very high speed (tpd 5-10ns), Over-voltage tolerant inputs, Output register
  • Inputs Are TTL-Voltage Compatible
  • 8-Bit Serial-In, Parallel-Out Shift Registers
    With Storage
  • Independent Direct Overriding Clears on Shift
    and Storage Registers
  • Independent Clocks for Both Shift and Storage
    Registers
  • Latch-Up Performance Exceeds 100 mA Per JESD,
    78 Class II
  • ESD Protection Exceeds JESD 22
    • 3500-V Human-Body Model
    • 200-V Machine Model
    • 2000-V Charged-Device Model
The SN74AHCT594 device contains an 8-bit serial-in, parallel-out shift register that feeds an 8-bit D-type storage register.
