公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
具有时钟使能端的八路 D 型触发器
Number of channels (#) 8
Technology Family HCT
Supply voltage (Min) (V) 4.5
Supply voltage (Max) (V) 5.5
Input type TTL-Compatible CMOS
Output type Push-Pull
Clock Frequency (Max) (MHz) 35
IOL (Max) (mA) 4
IOH (Max) (mA) -4
ICC (Max) (uA) 80
Features Balanced outputs, High speed (tpd 10-50ns), Positive input clamp diode
  • Operating Voltage Range of 4.5 V to 5.5 V
  • Outputs Can Drive Up To 10 LSTTL Loads
  • Low Power Consumption, 80-&miccro;A Max ICC
  • Typical tpd = 12 ns
  • ±4-mA Output Drive at 5 V
  • Low Input Current of 1 μA Max
  • Inputs Are TTL-Voltage Compatible
  • Contain Eight Flip-Flops With Single-Rail Outputs
  • Clock Enable Latched to Avoid False Clocking
  • Applications Include:
    • Buffer/Storage Registers
    • Shift Registers
    • Pattern Generators
These devices are positive-edge-triggered D-type flip-flops. The ?HCT377 devices are similar to the ?'HCT273 devices, but feature a latched clock-enable (CLKEN)\ input instead of a common clear.
Information at the data (D) inputs meeting the setup time requirements is transferred to the Q outputs on the positive-going edge of the clock (CLK) pulse if CLKEN\ is low. Clock triggering occurs at a particular voltage level and is not directly related to the transition time of the positive-going pulse. When CLK is at either the high or low level, the D input has no effect at the output. These devices are designed to prevent false clocking by transitions at CLKEN\.
