公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  189粉丝
--- 产品详情 ---
具有三态输出的 10 位总线接口 D 类锁存器
Number of channels (#) 10
Technology Family FCT
Supply voltage (Min) (V) 4.75
Supply voltage (Max) (V) 5.25
Input type TTL-Compatible CMOS
Output type 3-State
Clock Frequency (Max) (MHz) 70
IOL (Max) (mA) 64
IOH (Max) (mA) -32
ICC (Max) (uA) 200
Features Very high speed (tpd 5-10ns), Partial power down (Ioff), Flow-through pinout
  • Function, Pinout, and Drive Compatible With FCT, F, and AM29841 Logic
  • Reduced VOH (Typically = 3.3 V) Versions of Equivalent FCT Functions
  • Edge-Rate Control Circuitry for Significantly Improved Noise Characteristics
  • Ioff Supports Partial-Power-Down Mode Operation
  • Matched Rise and Fall Times
  • ESD Protection Exceeds JESD 22
    • 2000-V Human-Body Model (A114-A)
    • 200-V Machine Model (A115-A)
    • 1000-V Charged-Device Model (C101)
  • Fully Compatible With TTL Input and Output Logic Levels
  • High-Speed Parallel Latches
  • Buffered Common Latch-Enable Input
  • 3-State Outputs
  • CY54FCT841T
    • 32-mA Output Sink Current
    • 12-mA Output Source Current
  • CY74FCT841T
    • 64-mA Output Sink Current
    • 32-mA Output Source Current
The \x92FCT841T bus-interface latches are designed to eliminate additional packages required to buffer existing latches and provide additional data width for wider address/data paths or buses carrying parity. The \x92FCT841T devices are buffered 10-bit-wide versions of the FCT373 function.
The \x92FCT841T devices\x92 high-performance interface is designed for high-capacitance-load drive capability, while providing low-capacitance bus loading at both inputs and outputs. Outputs are designed for low-capacitance bus loading in the high-impedance state.
These devices are fully specified for partial-power-down applications using Ioff. The Ioff circuitry disables the outputs, preventing damaging current backflow through the device when it is powered down.
