公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  190粉丝
--- 产品详情 ---
具有输出寄存器的 8 位移位寄存器
Configuration Serial-in, Parallel-out
Bits (#) 8
Technology Family AHC
Supply voltage (Min) (V) 2
Supply voltage (Max) (V) 5.5
Input type Standard CMOS
Output type Push-Pull
Clock Frequency (MHz) 115
IOL (Max) (mA) 8
IOH (Max) (mA) -8
ICC (Max) (uA) 40
Features Balanced outputs, Very high speed (tpd 5-10ns), Over-voltage tolerant inputs, Output register
  • Operating Range 2-V to 5.5-V VCC
  • 8-Bit Serial-In, Parallel-Out Shift Registers with Storage
  • Independent Direct Overriding Clears on Shift and Storage
    Registers
  • Independent Clocks for Shift and Storage Registers
  • Latch-Up Performance Exceeds 100 mA Per JESD 78,
    Class II
  • ESD Protection Exceeds JESD 22
    • 2000-V Human-Body Model (A114-A)
    • 200-V Machine Model (A115-A)
    • 1000-V Charged-Device Model (C101)
The SNx4AHC594 devices contain an 8-bit serial-in, parallel-out shift register that feeds an 8-bit D-type storage register. Separate clocks and direct overriding clear (SRCLR, RCLR) inputs are provided on the shift and storage registers. A serial (QH′) output is provided for cascading purposes.
