公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  190粉丝
--- 产品详情 ---
具有清零端的八路正边沿触发式 D 型触发器
Number of channels (#) 8
Technology Family ALS
Supply voltage (Min) (V) 4.5
Supply voltage (Max) (V) 5.5
Input type Bipolar
Output type Push-Pull
Clock Frequency (Max) (MHz) 70
IOL (Max) (mA) 24
IOH (Max) (mA) -2.6
ICC (Max) (uA) 29000
Features High speed (tpd 10-50ns)
  • Contain Eight Flip-Flops With Single-Rail Outputs
  • Buffered Clock and Direct-Clear Inputs
  • Individual Data Input to Each Flip-Flop
  • Applications Include:
  • Buffer/Storage Registers
  • Shift Registers
  • Pattern Generators
  • Package Options Include Plastic Small-Outline (DW) Packages, Ceramic Chip Carriers (FK), and Standard Plastic (N) and Ceramic (J) 300-mil DIPs
These octal positive-edge-triggered flip-flops utilize TTL circuitry to implement D-type flip-flop logic with a direct-clear () input.
Information at the data (D) inputs meeting the setup-time requirements is transferred to the Q outputs on the positive-going edge of the clock (CLK) pulse. Clock triggering occurs at a particular voltage level and is not directly related to the transition time of the positive-going pulse. When CLK is at either the high or low level, the D input signal has no effect at the output.
The SN54ALS273 is characterized for operation over the full military temperature range of -55°C to 125°C. The SN74ALS273 is characterized for operation from 0°C to 70°C.
