公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
具有输出锁存器的串行输入移位寄存器
Configuration Serial-in, Parallel-out
Bits (#) 8
Technology Family LS
Supply voltage (Min) (V) 4.75
Supply voltage (Max) (V) 5.25
Input type Bipolar
Output type Push-Pull
Clock Frequency (MHz) 25
IOL (Max) (mA) 24
IOH (Max) (mA) -2.6
ICC (Max) (uA) 65000
Features High speed (tpd 10-50ns)
  • 8-Bit Serial-In, Parallel-Out Shift Registers with Storage
  • Choice of Output Configurations:
    'LS594 . . . Buffered
    'LS599 . . . Open-Collector
  • Guaranteed Shift Frequeny:
    DC to 20 MHz
  • Independent Direct-Overriding Clears on Shift and Storage Registers
These devices each contain an 8-bit D-type sorage register. The storage register has buffered ('LS594) or open-collector ('LS599) outputs. Separate clocks and direct-overriding clears are provided on both the shift and storage registers. A shift output (QH') is provided for cascading purposes.
Both the shift register and the storage register clocks are positive-edge triggered. If the user wishes to connect both clocks together, the shift register will always be one clock pulse ahead of the storage register.
