| Configuration | Serial-in, Parallel-out |
| Bits (#) | 8 |
| Technology Family | LS |
| Supply voltage (Min) (V) | 4.75 |
| Supply voltage (Max) (V) | 5.25 |
| Input type | Bipolar |
| Output type | Push-Pull |
| Clock Frequency (MHz) | 25 |
| IOL (Max) (mA) | 24 |
| IOH (Max) (mA) | -2.6 |
| ICC (Max) (uA) | 65000 |
| Features | High speed (tpd 10-50ns), Output register |
- 8-Bit Serial-In, Parallel-Out Shift Registers with Storage
- Choice of 3-State ('LS595) or Open-Collector ('LS596) Parallel Outputs
- Shift Register Has Direct Clear
- Accurate Shift Frequency:DC to 20 MHz
These devices each contain an 8-bit serial-in, parallel-out shift register that feeds an 8-bit D-type storage register. The storage register has parallel 3-state ('LS595) or open-collector ('LS596) outputs. Separate clocks are provided for both the shift register and the storage register. The shift register has a direct-overriding clear, serial input, and serial output pins for cascading.
Both the shift register and storage register clocks are positive-edge triggered. If the user wishes to connect both clocks together, the shift register state will always be one clock pulse ahead of the storage register.
