公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
具有输入锁存器的串行输出移位寄存器
Configuration Parallel-in, Serial-out
Bits (#) 8
Technology Family LS
Supply voltage (Min) (V) 4.75
Supply voltage (Max) (V) 5.25
Input type Bipolar
Output type Push-Pull
Clock Frequency (MHz) 25
IOL (Max) (mA) 24
IOH (Max) (mA) -2.6
ICC (Max) (uA) 53000
Features High speed (tpd 10-50ns)
  • 8-Bit Parallel Storage Register Inputs ('LS597)
  • Parallel 3-State I/O, Storage Register Inputs, Shift Register Outputs ('LS598)
  • Shift Register has Direct Overriding Load and Clear
  • Accurate Shift-Frequency … DC to 20 MHz
The 'LS597 comes in a 16-pin package and consists of an 8-bit storage latch feeding a parallel-in, serial-out 8-bit shift register. Both the storage register and shift register have positive-edge triggered clocks. The shift register also has direct load (from storage) and clear inputs.
The 'LS598 comes in a 20-pin package and has all the features of the 'LS597 plus 3-state I/O ports that provide parallel shift register outputs and also has multiplexed serial data inputs.
