公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
具有复位功能的四路 D 型触发器
Number of channels (#) 4
Technology Family ACT
Supply voltage (Min) (V) 4.5
Supply voltage (Max) (V) 5.5
Input type TTL-Compatible CMOS
Output type Push-Pull
Clock Frequency (Max) (MHz) 114
IOL (Max) (mA) 24
IOH (Max) (mA) -24
ICC (Max) (uA) 80
Features Balanced outputs, Very high speed (tpd 5-10ns), Positive input clamp diode
  • Inputs Are TTL-Voltage Compatible
  • Contains Four Flip-Flops With Double-Rail Outputs
  • Buffered Inputs
  • Speed of Bipolar F, AS, and S, With Significantly Reduced Power Consumption
  • Balanced Propagation Delays
  • ±24-mA Output Drive Current
    • Fanout to 15 F Devices
  • SCR-Latchup-Resistant CMOS Process and Circuit Design
  • Exceeds 2-kV ESD Protection Per MIL-STD-883, Method 3015
  • Applications Include:
    • Buffer/Storage Registers
    • Shift Registers
    • Pattern Generators
This positive-edge-triggered D-type flip-flop has a direct clear (CLR)\ input. The CD74ACT175 features complementary outputs from each flip-flop.
Information at the data (D) inputs meeting the setup time requirements is transferred to the outputs on the positive-going edge of the clock (CLK) pulse. Clock triggering occurs at a particular voltage level and is not directly related to the transition time of the positive-going edge of CLK. When CLK is at either the high or low level, the D input has no effect at the output.
