| Number of channels (#) | 8 |
| Technology Family | AS |
| Supply voltage (Min) (V) | 4.5 |
| Supply voltage (Max) (V) | 5.5 |
| Input type | Bipolar |
| Output type | 3-State |
| Clock Frequency (Max) (MHz) | 100 |
| IOL (Max) (mA) | 48 |
| IOH (Max) (mA) | -15 |
| ICC (Max) (uA) | 142000 |
| Features | Very high speed (tpd 5-10ns) |
- 3-State Buffer-Type Noninverting Outputs Drive Bus Lines Directly
- Bus-Structured Pinout
- Buffered Control Inputs
- SN74ALS575A and ′AS575 Have Synchronous Clear
- Package Options Include Plastic Small-Outline (DW) Packages, Ceramic Chip Carriers (FK), Standard Plastic (N, NT) and Ceramic (J, JT) 300-mil DIPs, and Ceramic Flat (W) Packages
These octal D-type edge-triggered flip-flops feature 3-state outputs designed specifically for bus driving. They are particularly suitable for implementing buffer registers, I/O ports, bidirectional bus drivers, and working registers.
The eight flip-flops enter data on the low-to-high transition of the clock (CLK) input. The SN74ALS575A, SN54AS575, and SN74AS575 may be synchronously cleared by taking the clear (
) input low.
The output-enable (
) input does not affect internal operations of the flip-flops. Old data can be retained or new data can be entered while the outputs are in the high-impedance state.
The SN54ALS574B, SN54AS574, and SN54AS575 are characterized for operation over the full military temperature range of -55°C to 125°C. The SN74ALS574B, SN74ALS575A, SN74AS574, and SN74AS575 are characterized for operation from 0°C to 70°C.
