公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
具有时钟使能端的八路 D 型触发器
Number of channels (#) 8
Technology Family F
Supply voltage (Min) (V) 4.5
Supply voltage (Max) (V) 5.5
Input type Bipolar
Output type Push-Pull
Clock Frequency (Max) (MHz) 110
IOL (Max) (mA) 20
IOH (Max) (mA) -1
ICC (Max) (uA) 90000
Features Very high speed (tpd 5-10ns)
  • Contains Eight D-Type Flip-Flops With Single-Rail Outputs
  • Clock Enable Latched to Avoid False Clocking
  • Applications Include:
  • Buffer/Storage Registers
  • Shift Registers
  • Pattern Generators
  • Buffered Common Enable Input
  • Package Options Include Plastic Small-Outline Packages and Standard Plastic 300-mil DIPs
The SN74F377A is a monolithic, positive-edge-triggered, octal, D-type flip-flop with clock enable inputs. The SN74F377A features a latched clock enable () input.
Information at the data (D) inputs meeting the setup time requirements is transferred to the Q outputs on the positive-going edge of the clock pulse if is low. Clock triggering occurs at a particular voltage level and is not directly related to the positive-going pulse. When the clock input is at either the high or low level, the D input signal has no effect at the output. The circuits are designed to prevent false clocking by transitions at the input.
The SN74F377A is characterized for operation from 0°C to 70°C.
