公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
具有漏极开路输出的汽车类施密特触发输入四路 2 输入异或非门
Technology Family HCS
Number of channels (#) 4
Supply voltage (Min) (V) 2
Supply voltage (Max) (V) 6
Inputs per channel 2
IOL (Max) (mA) 7.8
IOH (Max) (mA) 0
Output type Open-Drain
Input type Schmitt-Trigger
Features High speed (tpd 10-50ns)
Data rate (Max) (Mbps) 70
Rating Automotive
  • AEC-Q100 Qualified for automotive applications:
    • Device temperature grade 1: –40°C to +125°C, TA
    • Device HBM ESD Classification Level 2
    • Device CDM ESD Classifcation Level C6
  • Wide operating voltage range: 2 V to 6 V
  • Schmitt-trigger inputs allow for slow or noisy input signals
  • Low power consumption
    • Typical ICC of 100 nA
    • Typical input leakage current of ±100 nA
  • ±7.8-mA output drive at 6 V
This device contains four independent 2-input XNOR gates with open-drain outputs and Schmitt-trigger inputs. Each gate performs the Boolean function Y = A ⊕ B in positive logic.
