| Technology Family | F |
| Supply voltage (Min) (V) | 4.5 |
| Supply voltage (Max) (V) | 5.5 |
| Number of channels (#) | 4 |
| Inputs per channel | 2 |
| IOL (Max) (mA) | 20 |
| Input type | Bipolar |
| IOH (Max) (mA) | -1 |
| Output type | Push-Pull |
| Features | Very high speed (tpd 5-10ns) |
| Data rate (Max) (Mbps) | 70 |
| Rating | Catalog |
| Operating temperature range (C) | 0 to 70 |
- Package Options Include Plastic Small-Outline (D) Packages, Ceramic Chip Carriers (FK), and Standard Plastic (N) and Ceramic (J) 300-mil DIPs
EPIC is a trademark of Texas Instruments Incorporated.
These devices contain four independent 2-input exclusive-OR gates. They perform the Boolean function Y = A
B or Y = A\B + AB\ in positive logic.
A common application is as a true/complement element. If one of the inputs is low, the other input is reproduced in true form at the output. If one of the inputs is high, the signal on the other input is reproduced inverted at the output.
The SN54F86 is characterized for operation over the full military temperature range of -55°C to 125°C. The SN74F86 is characterized for operation from 0°C to 70°C.
