| Technology Family | S |
| Supply voltage (Min) (V) | 4.5 |
| Supply voltage (Max) (V) | 5.5 |
| Number of channels (#) | 4 |
| Inputs per channel | 2 |
| IOL (Max) (mA) | 20 |
| IOH (Max) (mA) | -1 |
| Input type | Bipolar |
| Output type | Push-Pull |
| Features | High speed (tpd 10- 50ns) |
| Data rate (Max) (Mbps) | 40 |
| Rating | Catalog |
- Package Options Include:
- Plastic Small-Outline (D, NS, PS)
- Shrink Small-Outline (DB)
- Ceramic Flat (W)
- Ceramic Chip Carriers (FK)
- Standard Plastic (N)
- Ceramic (J)
- Also Available as Dual 2-Input Positive-NAND Gate in Small-Outline (PS) Package
- Inputs Are TTL Compliant; VIH = 2 V and
VIL = 0.8 V - Inputs Can Accept 3.3-V or 2.5-V Logic Inputs
- SN5400, SN54LS00, and SN54S00 are Characterized For Operation Over the Full Military Temperature Range of –55oC to 125oC
The SNx4xx00 devices contain four independent,
2-input NAND gates. The devices perform the Boolean function Y = A .B or Y = A + B in positive logic.
