| Technology Family | S |
| Supply voltage (Min) (V) | 4.75 |
| Supply voltage (Max) (V) | 5.25 |
| Number of channels (#) | 4 |
| Inputs per channel | 2 |
| IOL (Max) (mA) | 20 |
| IOH (Max) (mA) | 0 |
| Input type | Bipolar |
| Output type | Open-Collector |
| Features | High speed (tpd 10- 50ns) |
| Data rate (Max) (Mbps) | 50 |
| Rating | Catalog |
| Operating temperature range (C) | 0 to 70 |
- Package Options Include Plastic “Small Outline" Packages, Ceramic Chip Carriers and Flat Packages, and Plastic and Ceramic DIPS
- Dependable Texas Instruments Quality and Reliability
These devices contain four independent 2-input AND gates. The open-collector outputs require pull-up resistors to perform correctly. They may be connected to other open-collector outputs to implement active-low wired-OR or active-high wired-AND functions. Open-collector devices are often used to generate higher VOH levels.
The SN5409, SN54LS09, and SN54S09 are characterized for operation over the full military temperature range of -55°C to 125°C, The SN7409, SN74LS09, and SN74S09 are characterized for operation from 0°C to 70°C.
