公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
具有集电极开路输出的 4 通道、2 输入、4.75V 至 5.25V 双极与非门
Technology Family S
Supply voltage (Min) (V) 4.75
Supply voltage (Max) (V) 5.25
Number of channels (#) 4
Inputs per channel 2
IOL (Max) (mA) 48
IOH (Max) (mA) 0
Input type Bipolar
Output type Open-Collector
Features High speed (tpd 10- 50ns)
Data rate (Max) (Mbps) 50
Rating Catalog
  • Package Options Include Plastic “Small Outline" Packages, Ceramic Chip Carriers and Flat Packages, and Plastic and Ceramic DIPs
  • Dependable Texas Instruments Quality and Reliability
These devices contain four independent 2-input NAND buffer gates with open-collector outputs. The open-collector outputs require pull-up resistors to perform correctly. They may be connected to other open-collector outputs to implement active-low wired-OR or active-high wired-AND functions. Open-collector devices are often used to generate high VOH levels.
The SN5438, SN54LS38, and SN54S38 are characterized for operation over the full military temperature range of -55°C to 125°C. The SN7438, SN74LS38, and SN74S38 are characterized for operation from 0°C to 70°C.
