公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
军用 4 通道、2 输入、2V 至 5.5V XOR(异或)门
Technology Family AC
Supply voltage (Min) (V) 2
Supply voltage (Max) (V) 5.5
Number of channels (#) 4
Inputs per channel 2
IOL (Max) (mA) 24
Input type Standard CMOS
IOH (Max) (mA) -24
Output type Push-Pull
Features Very high speed (tpd 5-10ns)
Data rate (Max) (Mbps) 100
Rating Military
Operating temperature range (C) -55 to 125
  • 2-V to 6-V VCC Operation
  • Inputs Accept Voltages to 6 V
  • Max tpd of 9 ns at 5 V
The ?AC86 devices are quadruple 2-input exclusive-OR gates. The devices perform the Boolean function Y = A B or Y = A\B + AB\ in positive logic.
A common application is as a true/complement element. If one of the inputs is low, the other input is reproduced in true form at the output. If one of the inputs is high, the signal on the other input is reproduced inverted at the output.
