公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  180粉丝
--- 产品详情 ---
用于 IC-USB 接口的电压电平转换器
Technology Family AVC
Applications IC-USB
Rating Catalog
Operating temperature range (C) -40 to 85
  • VCCA, VCCB Supply Voltage: 1.1 V to 3.6 V
  • When VCCB = 0 V, A-Port is Disabled and B-Port is Held
    at GND Through 120-k Pulldown
  • Crossover Skew of <1 ns
  • Meets All Requirements of the IC-USB Standard
  • Small Package: 0.4 mm pitch WCSP
    (1.2 mm × 1.6 mm)
  • Latch-Up Performance Exceeds 100 mA Per JESD 78,
    Class II ESD Performance
    • A-Port (Host Side)
      • 2000-V Human-Body Model
      • 1000-V Charged-Device Model
    • B-Port (Peripheral Side)
      • 8000-V Contact Discharge
      • 15000-V Air-Gap Discharge
The SN74AVC2T872 is a 2-bit voltage level translator optimized for use in interchip USB (IC-USB) applications. VCCA and VCCB can each operate over the full range of 1.1 V to 3.6 V. The device has been designed to maintain crossover skew to be less than 1 ns. Each B-port has an integrated 120-k pulldown resistor that can be enabled and disabled using the PD_EN control signal. If VCCB = 0 V, the A-port I/Os are disabled (Hi-Z) and the B-port I/Os are held to GND through the 120-k resistors. If VCCA = 0 V, the A-port and B-port I/Os are disabled (Hi-Z).
