Technology Family | TXS |
Applications | SDIO, MMC, SD Card |
Rating | Catalog |
Operating temperature range (C) | -40 to 85 |
- Level Translator
- VCCA and VCCB Range of 1.1 V to 3.6 V
- Fast Propagation Delay (4 ns Max When Translating
Between 1.8 V and 3 V)
- Integrated EMI Filtering and ESD Protection Circuitry
- ESD Protection Exceeds JESD 22 (A Port)
- 2500-V Human-Body Model (A114-B)
- 250-V Machine Model (A115-A)
- 1500-V Charged-Device Model (C101)
- ±8-kV Contact Discharge IEC 61000-4-2 ESD (B-port)
All other trademarks are the property of their respective owners.
The TXS0206 is a level shifter for interfacing microprocessors with MultiMediaCards (MMCs), secure digital (SD) cards, and Memory Stick? cards. It includes a high-speed level translator along with ESD protection and EMI filtering circuitry.
The voltage-level translator has two supply voltage pins. VCCA as well as VCCB can be operated over the full range of 1.1 V to 3.6V. The TXS0206 enables system designers to easily interface applications processors or digital basebands to memory cards and SDIO peripherals operating at a different I/O voltage level.
Memory card standards recommend high-ESD protection for devices that connect directly to the external memory card. To meet this need, the TXS0206 incorporates ±8-kV Contact Discharge protection on the card side.
The TXS0206 is offered in a 20-bump wafer chip scale package (WCSP). This package has dimensions of 1.96mm×1.56mm, with a 0.4-mm ball pitch for effective board-space savings. Memory cards are widely used in mobile phones, PDAs, digital cameras, personal media players, camcorders, set-top boxes, etc. Low static power consumption and small package size make the TXS0206 an ideal choice for these applications.
