公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  187粉丝
--- 产品详情 ---
具有集成电流调节功能的 35V、3.7A H 桥电机驱动器
Number of full bridges 1
Vs (Min) (V) 4.5
Vs ABS (Max) (V) 35
Peak output current (A) 3.7
RDS(ON) (HS + LS) (mOhms) 600
Sleep current (uA) 1
Control mode PWM
Control interface Hardware (GPIO)
Features Current Regulation, Low-Power Sleep Mode
Rating Catalog
Operating temperature range (C) -40 to 150
  • N-channel H-bridge brushed DC motor driver
  • 4.5-V to 33-V operating supply voltage range
  • Pin-to-pin, RDS(on), voltage, and current sense/regulation variants (external shunt resistor and integrated current mirror)
    • DRV8870: 6.5-V to 45-V, 565-mΩ, shunt
    • DRV8251: 4.5-V to 48-V, 450-mΩ, shunt
    • DRV8251A: 4.5-V to 48-V, 450-mΩ, mirror
    • DRV8231: 4.5-V to 33-V, 600-mΩ, shunt
    • DRV8231A: 4.5-V to 33-V, 600-mΩ, mirror
  • High output current capability: 3.7-A Peak
  • PWM control interface
  • Supports 1.8-V, 3.3-V, and 5-V logic inputs
  • Integrated current regulation
  • Low-power sleep mode
    • <1-μA at VVM = 24-V, TJ = 25°C
  • Small package and footprint
    • 8-Pin WSON with PowerPAD?, 2.0 × 2.0 mm
    • 8-Pin HSOP with PowerPAD?, 4.9 × 6.0 mm
  • Integrated protection features
    • VM undervoltage lockout (UVLO)
    • Auto-retry overcurrent protection (OCP)
    • Thermal shutdown (TSD)
The DRV8231 device is an integrated motor driver with N-channel H-bridge, charge pump, current regulation, and protection circuitry. The charge pump improves efficiency by supporting N-channel MOSFET half bridges and 100% duty cycle driving.
The DRV8231 implements a current regulation feature by comparing the analog input VREF and the voltage across a current-sense shunt resistor on the ISEN pin. The ability to limit current can significantly reduce large currents during motor startup and stall conditions.
A low-power sleep mode achieves ultra-low quiescent current draw by shutting down most of the internal circuitry. Internal protection features include supply undervoltage lockout, output overcurrent, and device overtemperature.
The DRV8231 is part of a family of devices which come in pin-to-pin, scalable RDS(on) and supply voltage options to support various loads and supply rails with minimal design changes. See Section 5 for information on the devices in this family. View the full portfolio of brushed motor drivers on ti.com.
