公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  187粉丝
--- 产品详情 ---
具有直流/直流转换器的组合电机驱动器
Number of full bridges 4
Vs (Min) (V) 7
Vs ABS (Max) (V) 50
Peak output current (A) 3
RDS(ON) (HS + LS) (mOhms) 550
Sleep current (uA) 7000
Control mode PH/EN
Control interface Hardware (GPIO)
Rating Catalog
Operating temperature range (C) -10 to 50
  • Configurable to Eight Modes of Combination Motor Driver
    • Bipolar Stepper Motor Driver
      • 16-Step Current-Mode Control
      • 800-mA Average Output Current as Stepper
        Motor Drive
    • DC Motor Driver
      • 800-mA Maximum Continuous Current and
        8-A/500-ns or 3-A/100-ms Peak Current for
        Each DC Motor Drive
    • Low ON resistance Rds(ON) = 0.55 Ω at TJ=25°C(Typ)
  • Three Integrated DC-DC Converters
    • On/Off Selectable Using C_SELECT Pin and Serial
      Interface
    • Outputs Programmable With External Resistor Network
      From 1.5 V to VDIN × 0.8
    • 1.5-A Output Capability for All Three Channels
  • 7-V to 40-V Operating Voltage Range for DC-DC Converters
  • Two Serial Interfaces for Communications
  • Thermally Enhanced Surface-Mount 64-Pin QFP PowerPAD?
    Package (Eco-Friendly – RoHS and No Sb/Br)
  • Power-Down Function (Deep-Sleep Mode)
  • Reset Signal Output (Active Low)
  • Reset (All Clear) Control Input
The DRV8809/DRV8810 provides an integrated motor driver solution. The chip has four H-bridges internally and is configurable to eight different modes of combination motor driver control.
The output driver block for each H-bridge consists of N-channel power MOSFETs configured as full H-bridges to drive the motor windings. The stepper motor control has a 16-step mode programmable through the 3-wire serial interface (SPI). The SPI input pins are 3.3-V compatible and 5-V tolerant.
The DRV8809/DRV8810 has three DC-DC switch-mode buck converters to generate a programmable output voltage from 1.5V to 80% of VDIN (channel A) or up to 10V (for channel B and channel C), with up to 1.5-A load current capability. The outputs are selected using the C_SELECT terminal at start-up or using serial interface during operation.
An internal shutdown function is provided for overcurrent protection (OCP), short-circuit protection, overvoltage/undervoltage lockout (UVLO), and thermal shutdown (TSD). Also, the device has a reset function that operates at power on and at input to the In-Reset pin.
