公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  187粉丝
--- 产品详情 ---
具有死区控制的 30V 半桥栅极驱动器
Bus voltage (Max) (V) 30
Power switch MOSFET
Input VCC (Min) (V) 4.5
Input VCC (Max) (V) 5.5
Peak output current (A) 4
Rise time (ns) 15
Operating temperature range (C) -40 to 105
Undervoltage lockout (Typ) 3.7
Rating Catalog
Number of channels (#) 2
Fall time (ns) 10
Prop delay (ns) 25
Iq (uA) 500
Channel input logic TTL
Negative voltage handling at HS pin (V) -0.1
Features Dead Time Control
Driver configuration Dual
  • High Voltage Synchronous Buck Driver
  • Integrated Boost Switch for Bootstrap Action
  • Adaptive Dead Time Control and Shoot-through Protection
  • 0.4-Ω Sink Resistance for Low-side Drive
  • 1.0-Ω Source Resistance for High-side Drive
  • SKIP Pin to Improve Light-Load Efficiency
  • Adaptive Zero-Crossing Detection for Optimal Light-Load Efficiency
  • 8-Pin 3mm × 3mm SON (DRB) Package
The TPS51601A is a synchronous buck MOSFET driver with integrated boost switch. This high-performance driver is capable of driving high-side and low-side side N-channel FETs with the highest speed and lowest switching loss. Adaptive dead-time control and shoot-through protection are included.
The TPS51601A is available in the space-saving 8-pin 3 mm × 3 mm SON package and operates between –40°C and 105°C.
