公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  187粉丝
--- 产品详情 ---
具有 TTL 输入和使能功能、用于同相同步降压的 2.4A、28V 半桥栅极驱动器
Bus voltage (Max) (V) 28
Power switch MOSFET
Input VCC (Min) (V) 4.5
Input VCC (Max) (V) 15
Peak output current (A) 2.4
Rise time (ns) 50
Operating temperature range (C) -40 to 125
Rating Catalog
Number of channels (#) 2
Fall time (ns) 40
Prop delay (ns) 70
Iq (uA) 3000
Input threshold TTL
Channel input logic TTL
Negative voltage handling at HS pin (V) 0
Features Dead Time Control, Synchronous Rectification
Driver configuration Non-Inverting
  • Floating Bootstrap or Ground-Reference High-Side Driver
  • Adaptive Dead-Time Control
  • 50-ns Max Rise/Fall Times With 3.3-nF Load
  • 2.4-A Typical Output Current
  • 4.5-V to 15-V Supply Voltage Range
  • TTL-Compatible Inputs
  • Internal Schottky Bootstrap Diode
  • Low Supply Current....3 mA Typical
  • Ideal for High-Current Single or Multiphase Power Supplies
  • –40°C to 125°C Operating Virtual Junction-Temperature Range
The TPS2836 and TPS2837 are MOSFET drivers for synchronous-buck power stages. These devices are ideal for designing a high-performance power supply using switching controllers that do not have MOSFET drivers. The drivers are designed to deliver minimum 2-A peak currents into large capacitive loads. The high-side driver can be configured as ground-reference or as floating-bootstrap. An adaptive dead-time control circuit eliminates shoot-through currents through the main power FETs during switching transitions and provides high efficiency for the buck regulator.
The TPS2836 has a noninverting input, while the TPS2837 has an inverting input. These drivers, available in 8-terminal SOIC packages, operate over a junction temperature range of ?40°C to 125°C.
