公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  190粉丝
--- 产品详情 ---
具有 CMOS 输入、用于同相同步降压的 2.4A、28V 半桥栅极驱动器
Bus voltage (Max) (V) 28
Power switch MOSFET
Input VCC (Min) (V) 4.5
Input VCC (Max) (V) 15
Peak output current (A) 2.4
Rise time (ns) 50
Operating temperature range (C) -40 to 125
Rating Catalog
Number of channels (#) 2
Fall time (ns) 50
Prop delay (ns) 75
Iq (uA) 3000
Input threshold CMOS
Channel input logic CMOS
Negative voltage handling at HS pin (V) 0
Features Dead Time Control, Synchronous Rectification
Driver configuration Non-Inverting
  • Floating Bootstrap or Ground-Reference High-Side Driver
  • Adaptive Dead-Time Control
  • 50-ns Max Rise/Fall Times and 100-ns Max Propagation Delay \x96 3.3-nF Load
  • Ideal for High-Current Single or Multiphase Power Supplies
  • 2.4-A Typical Peak Output Current
  • 4.5-V to 15-V Supply Voltage Range
  • Internal Schottky Bootstrap Diode
  • Low Supply Current....3-mA Typical
  • \x9640°C to 125°C Operating Virtual Junction Temperature
  • Available in SOIC Package
The TPS2832 and TPS2833 are MOSFET drivers for synchronous-buck power stages. These devices are ideal for designing a high-performance power supply using switching controllers that do not have MOSFET drivers. The drivers are designed to deliver 2.4-A peak currents into large capacitive loads. The high-side driver can be configured as a ground-reference driver or as a floating bootstrap driver. An adaptive dead-time control circuit eliminates shoot-through currents through the main power FETs during switching transitions and provides high efficiency for the buck regulator.
The TPS2832 has a noninverting input. The TPS2833 has an inverting input. The TPS2832/33 drivers, available in 8-terminal SOIC packages, operate over a junction temperature range of \x9640°C to 125°C.
