| Function | Charger Front-End Protection |
| Number of series cells (Min) | 1 |
| Number of series cells (Max) | 1 |
| Features | Overvoltage, Overcurrent protection |
| Typical operating current (Typ) (uA) | 410 |
| Rating | Catalog |
| Vin (Max) (V) | 30 |
- Provides Protection for Three Variables:
- Input Overvoltage
- Input Overcurrent with Current Limiting
- Battery Overvoltage
- Maximum Input Voltage of 30 V
- Supports Up to 1.5-A Input Current
- Robust Against False Triggering Due to Current
Transients - Thermal Shutdown
- LDO Mode Voltage Regulation of 5 V
- Available in Space-Saving Small 2 mm × 2 mm 8-
Pin WSON Package - APPLICATIONS
- Mobile and Smart Phones
- PDAs
- MP3 Players
- Low-Power Handheld Devices
- Bluetooth? Headsets
All other trademarks are the property of their respective owners
The bq24308 device is a highly integrated circuit (IC) designed to provide protection to Li-ion batteries from failures of the charging circuit. The device continuously monitors the input voltage, the input current, and the battery voltage. In case of an input overvoltage condition, the device immediately removes power from the charging circuit by turning off an internal switch. In the case of an overcurrent condition, it limits the system current to a safe value for a blanking duration before turning the switch off. Battery voltage may also be monitored and if the battery voltage exceeds the specified value the internal switch is turned off. Additionally, the device also monitors its own die temperature and switches off if it becomes too hot.
The input overcurrent threshold can be increased using an external resistor. The device also offers optional protection against reverse voltage at the input using an external P-channel FET.
