公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
适用于 1 节和 2 节锂离子电池的 OMAP 兼容电量监测计
Cell chemistry Lead Acid, Li-Ion/Li-Polymer, NiCd, NiMH
Number of series cells Single Cell
Communication interface HDQ
Battery capacity (Min) (mAh) 300
Battery capacity (Max) (mAh) 6000
Implementation Pack, System
External capacity indication None
Features Coulomb Counter
Operating temperature range (C) -20 to 70
  • Reports Accurate State-of-Charge in Li-Ion and Li-Pol Cells, No System Processor Calculations Needed
  • Communicates Directly With the Integrated HDQ Engine in TI OMAP? Processors
  • Reports Cell Temperature and Voltage
  • High-Accuracy Coulometric Charge and Discharge Current Integration with Automatic Offset Cancellation
  • Requires No Offset Calibration
  • Programmable Input/Output Port
  • Internal Time-Base Eliminates External Crystal Oscillator
  • Four Automatic Low-Power Operating Modes
    • Active: < 100 μA
    • Sleep: < 2.5 μA
    • Ship: < 1.7 μA
    • Hibernate: < 1.5 μA
  • Small 8-Pin TSSOP Package
  • APPLICATIONS
    • PDAs
    • Smart Phones
    • MP3 Players
    • Digital Cameras
    • Internet Appliances
    • Handheld Devices
The bq26501, the first in the bqJUNIOR? family of advanced gas gauge device for handhald applications, is a highly accurate standalone single-cell Li-Ion and Li-Pol battery capacity monitoring and reporting device targeted at space limited portable applications. The device monitors a voltage drop across a small current sense resistor connected in series with the battery to determine charge and discharge activity of the battery. Compensations for battery temperature, self-discharge, and rate of discharge are applied to the charge counter to provide available capacity across a wide range of operating conditions. Battery capacity is automatically recalibrated, or learned, in the course of a discharge cycle from full to empty. Internal registers include available capacity, cell temperature and voltage, state-of-charge, and status and control registers.
The bq26501 can operate directly from single-cell Li-Ion and Li-Pol batteries and communicates to the system over a simple one-wire bi-directional serial interface. The 5-kbits/s HDQ bus interface reduces communication overhead in the external microcontroller.
