公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
锂离子电池充电控制器
Number of series cells 1, 2, 3, 4
Charge current (Max) (A) 0.015
Operating Vin (Max) (V) 20
Cell chemistry Li-Ion/Li-Polymer
Battery charge voltage (Min) (V) 4.2
Battery charge voltage (Max) (V) 4.2
Absolute Vin (safety rating) (Max) ((V)) 20
Control interface Standalone (RC-Settable)
Features IC thermal regulation
Operating Vin (Min) (V) 13
Rating Catalog
  • Input Voltage Range: up to 20 V
  • Voltage Options for Charging 1, 2, 3, or 4 Cells
  • Output Current up to 15 mA
  • Precision (0.5%) End-of-Charge Control
    • LM3420 ±1%
    • LM3420A ±0.5%
  • Drive Capability for External Power Stage
  • Temperature Drift Curvature Correction for
    Voltage Stability
  • Low Quiescent Current, 85 μA (Typ.)
  • Tiny SOT-23-5 package
The LM3420 series of controllers are monolithic integrated circuits designed for charging and end-of-charge control for lithium-ion rechargeable batteries. The LM3420 is available in an 8.4-V version for one through four cell charger applications.
Included in a very small package is an (internally compensated) op amp, a bandgap reference, an NPN output transistor, and voltage setting resistors. The amplifier?s inverting input is externally accessible for loop frequency compensation. The output is an open-emitter NPN transistor capable of driving up to 15 mA of output current into external circuitry.
A trimmed precision bandgap reference utilizes temperature drift curvature correction for excellent voltage stability over the operating temperature range. The LM3420 series allows for precision end-of-charge voltage threshold for lithium-ion rechargeable batteries. The premium grade LM3420A is available with an initial voltage threshold tolerance of ±0.5%, while the standard grade LM3420 has an initial voltage threshold tolerance of ±1%.
The LM3420 is available in a sub-miniature 5-lead surface mount package thus allowing very compact designs.
