公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
用于 DDR5 服务器 DIMM 的增强型高电流 PMIC
DDR memory type DDR5, DDR5 server
Control mode D-CAP+
Iout VDDQ (Max) (A) 6
Iq (Typ) (mA) 5
Output VDD, VDDQ, VPP
Vin (Min) (V) 4.5
Vin (Max) (V) 15
Features Complete Solution
Rating Catalog
The TPS53830A is D-CAP+? mode integrated step-down converter for DDR5 on-DIMM power supply, which provides VDD, VDDQ and VPP voltages to the DRAM chips on the DIMM module with configurable current capability. The high-current rail can be configured to 2-phase or 2 outputs to supply up to 12 A (or 6A + 6 A) current with D-CAP+? mode control. The converter also employs internal compensation for ease of use and reduce external components.
The converter provides a full set of telemetry, including input voltage, output voltage, and output current. overvoltage, undervoltage, overcurrent limit, and over-temperature protections are provided as well.
The TPS53830A is packaged in a thermally-enhanced 35-pin QFN and operates from -40°C to +105°C.
