| DDR memory type | DDR5, DDR5 server |
| Control mode | D-CAP+ |
| Iout VDDQ (Max) (A) | 6 |
| Iq (Typ) (mA) | 5 |
| Output | VDD, VDDQ, VPP |
| Vin (Min) (V) | 4.5 |
| Vin (Max) (V) | 15 |
| Features | Complete Solution |
| Rating | Catalog |
The TPS53832A is D-CAP+? mode integrated step-down converter for DDR5 on-DIMM power supply, which provides VDD, VDDQ and VPP voltages to the DRAM chips on the DIMM module with configurable current capability. The high-current rail can be configured to 2-phase or 2 outputs to supply up to 7 A (or 3.5A + 3.5 A) current with D-CAP+? mode control. The converter also employs internal compensation for ease of use and reduce external components.
The converter provides a full set of telemetry, including input voltage, output voltage, and output current. overvoltage, undervoltage, overcurrent limit, and over-temperature protections are provided as well.
The TPS53832A is packaged in a thermally-enhanced 35-pin QFN and operates from -40°C to +105°C.
