公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
6A 有源总线终端/DDR 存储器 SWIFT? 转换器
DDR memory type DDR, DDR2, DDR3
Control mode Voltage Mode
Iout VTT (Max) (A) 6
Iq (Typ) (mA) 11
Output VTT
Vin (Min) (V) 3
Vin (Max) (V) 6
Features Status Pin
Rating Catalog
  • Tracks Externally Applied Reference Voltage
  • 30-m, 12-A Peak MOSFET Switches for High Efficiency at 6-A Continuous Output Source or Sink Current
  • 6% to 90% VIN Output Tracking Range
  • PWM Frequency Range: Fixed 350 kHz or Adjustable 280 to 700 kHz
  • Load Protected by Peak Current Limit and Thermal Shutdown
  • Integrated Solution Reduces Board Area and Component Count
  • APPLICATIONS
    • DDR Memory Termination Voltage
    • Active Termination of GTL and STL High-Speed Logic Families
    • DAC Controlled High Current Output Stage
    • Precision Point of Load Power Supply
PowerPAD and SWIFT are trademarks of Texas Instruments.
As a member of the SWIFT? family of dc/dc regulators, the TPS54672 active bus termination synchronous PWM converter integrates all required active components. Included on the substrate with the listed features are a true, high performance, voltage error amplifier that enables maximum performance and flexibility in choosing the output filter L and C components; an under-voltage-lockout circuit to prevent start-up until the input voltage reaches 3 V; a slow-start control to limit in-rush currents; and a status output to indicate valid operating conditions.
The TPS54672 is available in a thermally enhanced 28-pin TSSOP (PWP) PowerPAD? package, which eliminates bulky heatsinks. TI provides evaluation modules and the SWIFT? designer software tool to aid in quickly achieving high-performance power supply designs to meet aggressive equipment development cycles.
