| Number of channels (#) | 2 |
| Power switch | MOSFET |
| Peak output current (A) | 2 |
| Input VCC (Min) (V) | 4 |
| Input VCC (Max) (V) | 14 |
| Features | 2-Input Gates Each Channel |
| Operating temperature range (C) | -40 to 125 |
| Rise time (ns) | 14 |
| Fall time (ns) | 15 |
| Prop delay (ns) | 25 |
| Input threshold | CMOS |
| Channel input logic | 2 Input AND |
| Input negative voltage (V) | 0 |
| Rating | Catalog |
| Driver configuration | Dual |
- Industry-Standard Driver Replacement
- 25-ns Max Rise/Fall Times and 40-ns Max Propagation Delay – 1-nF Load, VCC = 14 V
- 2-A Peak Output Current, VCC = 14 V
- 5-μA Supply Current — Input High or Low
- 4-V to 14-V Supply-Voltage Range; Internal Regulator Extends Range to 40 V (TPS2811, TPS2812, TPS2813)
- –40°C to 125°C Ambient-Temperature Operating Range
The TPS28xx series of dual high-speed MOSFET drivers are capable of delivering peak currents of 2 A into highly capacitive loads. This performance is achieved with a design that inherently minimizes shoot-through current and consumes an order of magnitude less supply current than competitive products.
The TPS2811, TPS2812, and TPS2813 drivers include a regulator to allow operation with supply inputs between 14 V and 40 V. The regulator output can power other circuitry, provided power dissipation does not exceed package limitations. When the regulator is not required, REG_IN and REG_OUT can be left disconnected or both can be connected to VCC or GND.
The TPS2814 and the TPS2815 have 2-input gates that give the user greater flexibility in controlling the MOSFET. The TPS2814 has AND input gates with one inverting input. The TPS2815 has dual-input NAND gates.
TPS28xx series drivers, available in 8-pin PDIP, SOIC, and TSSOP packages operate over a ambient temperature range of ?40°C to 125°C.
