公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  5k粉丝
--- 产品详情 ---
液晶显示驱动器(LCD 驱动器)
IC integration LCD bias
Vin (Min) (V) 3
Vin (Max) (V) 10
Source driver voltage (Min) (V) -0.3
Source driver voltage (Max) (V) 10
Level shifter/scan driver (ch) 0
Rating Catalog
  • Serial Data Input
  • No Load Signal Required
  • DATA ENABLE (MM5452)
  • Wide Power Supply Operation
  • TTL Compatibility
  • 32 or 33 Outputs
  • Alphanumeric and Bar Graph Capability
  • Cascaded Operation Capability
All trademarks are the property of their respective owners.
The MM5452 is a monolithic integrated circuit utilizing CMOS metal gate, low threshold enhancement mode devices. It is available in a 40-pin PDIP package. The chip can drive up to 32 segments of LCD and can be paralleled to increase this number. The chip is capable of driving a 4?-digit 7-segment display with minimal interface between the display and the data source.
The MM5452 stores display data in latches after it is clocked in, and holds the data until new display data is received.
