公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  188粉丝
--- 产品详情 ---
具有使能功能的汽车类 500mA、可调节低压降稳压器
Output options Adjustable Output
Iout (Max) (A) 0.5
Vin (Max) (V) 5.5
Vin (Min) (V) 2.7
Vout (Max) (V) 5.4
Vout (Min) (V) 1.2
Noise (uVrms) 33
Iq (Typ) (mA) 0.26
Thermal resistance θJA (°C/W) 48
Rating Automotive
Load capacitance (Min) (μF) 1
Regulated outputs (#) 1
Features Enable
Accuracy (%) 2
PSRR @ 100 KHz (dB) 40
Dropout voltage (Vdo) (Typ) (mV) 110
Operating temperature range (C) -40 to 125
  • Qualified for Automotive Applications
  • 500-mA Low-Dropout Regulator With Enable
  • High PSRR (50 dB at 10 kHz)
  • Ultralow Noise (33 μVRMS, TPS79501-Q1)
  • Fast Start-Up Time (50 μs)
  • Stable With a 1-μF Ceramic Capacitor
  • Excellent Load/Line Transient Response
  • Low Dropout Voltage (110 mV at Full Load, TPS79501-Q1)
  • APPLICATIONS
    • RF: VCOs, Receivers, ADCs
    • Audio
    • Bluetooth?, Wireless LAN
Bluetooth Is a trademark of Texas Instruments
The TPS79501-Q1 low-dropout (LDO), low-power linear voltage regulator features high power-supply rejection ratio (PSRR), ultralow noise, fast start-up, and excellent line and load transient responses in a small outline SON package. The device is stable with a small 1-μF ceramic capacitor on the output. The TPS79501-Q1 uses an advanced, proprietary BiCMOS fabrication process to yield extremely low dropout voltages (for example, 110 mV at 500 mA). The device achieves fast start-up times (approximately 50 μs with a 0.001-μF bypass capacitor) while consuming very low quiescent current (265 μA, typical). Moreover, when the device is placed in standby mode, the supply current is reduced to less than 1 μA. The TPS79501-Q1 exhibits approximately 33 μVRMS of output voltage noise at 3-V output with a 0.1-μF bypass capacitor. Applications with analog components that are noise-sensitive, such as portable RF electronics, benefit from the high-PSRR and low-noise features, as well as from the fast response time.
