公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  188粉丝
--- 产品详情 ---
具有反向电流保护功能的汽车类 400mA、高精度、低压降稳压器
Output options Adjustable Output, Fixed Output
Iout (Max) (A) 0.4
Vin (Max) (V) 5.5
Vin (Min) (V) 1.7
Vout (Max) (V) 5.4
Vout (Min) (V) 1.2
Fixed output options (V) 1.8
Noise (uVrms) 30
Iq (Typ) (mA) 0.4
Thermal resistance θJA (°C/W) 222
Rating Automotive
Load capacitance (Min) (μF) 0
Regulated outputs (#) 1
Features Enable, Reverse current protection
Accuracy (%) 1
PSRR @ 100 KHz (dB) 16
Dropout voltage (Vdo) (Typ) (mV) 75
Operating temperature range (C) -40 to 125
  • Qualified for Automotive Applications
  • AEC-Q100 Qualified With the Following Results:
    • Device Temperature Grade 1: –40°C to 125°C
      Ambient Operating Temperature Range
    • Device HBM ESD Classification Level 2
    • Device CDM ESD Classification Level C4B
  • Stable With No Output Capacitor or Any Value or
    Type of Capacitor
  • Input Voltage Range of 1.7 V to 5.5 V
  • Ultra-Low Dropout Voltage: 75-mV Typical
  • Excellent Load Transient Response—With Or
    Without Optional Output Capacitor
  • New NMOS Topology Delivers Low Reverse
    Leakage Current
  • Low Noise: 30-μVRMS Typical (10 Hz to 100 kHz)
  • 0.5% Initial Accuracy
  • 1% Overall Accuracy Over Line, Load, and
    Temperature
  • Less Than 1-μA Maximum IQ in Shutdown Mode
  • Thermal Shutdown and Specified Minimum and
    Maximum Current Limit Protection
  • Available in Multiple Output Voltage Versions
    • Fixed Outputs of 1.2 V to 3.3 V
    • Adjustable Output from 1.2 V to 5.5 V
The TPS736xx-Q1 family of low-dropout (LDO) linear voltage regulators uses a new topology: an NMOS pass element in a voltage-follower configuration. This topology is stable using output capacitors with low ESR, and even allows operation without a capacitor. It also provides high reverse blockage (low reverse current) and ground pin current that is nearly constant over all values of output current.
The TPS736xx-Q1 uses an advanced BiCMOS process to yield high precision while delivering very low dropout voltages and low ground pin current. Current consumption, when not enabled, is under 1μA and ideal for portable applications. The extremely low output noise (30 μ VRMS with 0.1-μF CNR) is ideal for powering VCOs. These devices are protected by thermal shutdown and foldback current limit.
