公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  188粉丝
--- 产品详情 ---
具有使能功能的 150mA、36V、低噪声、高 PSRR、可调节低压降稳压器
Output options Adjustable Output
Iout (Max) (A) 0.15
Vin (Max) (V) 36
Vin (Min) (V) 3
Vout (Max) (V) 33
Vout (Min) (V) 1.2
Noise (uVrms) 15
Iq (Typ) (mA) 0.06
Thermal resistance θJA (°C/W) 48
Rating Catalog
Load capacitance (Min) (μF) 2.2
Regulated outputs (#) 1
Features Enable, Soft start
Accuracy (%) 2.5
PSRR @ 100 KHz (dB) 54
Dropout voltage (Vdo) (Typ) (mV) 260
Operating temperature range (C) -40 to 125
  • Input Voltage Range: 3 V to 36 V
  • Noise:
    • 12.7 μVRMS (20 Hz to 20 kHz)
    • 15.4 μVRMS (10 Hz to 100 kHz)
  • Power-Supply Ripple Rejection:
    • 72 dB (120 Hz)
    • ≥ 52 dB (10 Hz to 400 kHz)
  • Adjustable Output: 1.194 V to 33 V
  • Output Current: 150 mA
  • Dropout Voltage: 260 mV at 100 mA
  • Stable with Ceramic Capacitors ≥ 2.2 μF
  • CMOS Logic-Level-Compatible Enable Pin
  • Fixed Current-Limit and Thermal Shutdown Protection
  • Packages: 8-Pin HVSSOP PowerPAD? and
    3-mm × 3-mm VSON
  • Operating Temperature Range:
    –40°C to 125°C
The TPS7A49 series of devices are positive, high-voltage (36 V), ultralow-noise (15.4 μVRMS, 72-dB PSRR) linear regulators that can source a 150-mA load.
These linear regulators include a CMOS logic-level-compatible enable pin and capacitor-programmable soft-start function that allows for customized power-management schemes. Other available features include built-in current limit and thermal shutdown protection to safeguard the device and system during fault conditions.
The TPS7A49 family is designed using bipolar technology, and is ideal for high-accuracy, high-precision instrumentation applications where clean voltage rails are critical to maximize system performance. This design makes the device an excellent choice to power operational amplifiers, analog-to-digital converters (ADCs), digital-to-analog converters (DACs), and other high-performance analog circuitry.
In addition, the TPS7A49 family of linear regulators is suitable for post dc-dc converter regulation. By filtering out the output voltage ripple inherent to dc-dc switching conversion, maximum system performance is provided in sensitive instrumentation, test and measurement, audio, and RF applications.
For applications where positive and negative high-performance rails are required, consider TI’s TPS7A30xx family of negative high-voltage, ultralow-noise linear regulators as well.
