Output options | Fixed Output |
Iout (Max) (A) | 0.15 |
Vin (Max) (V) | 40 |
Vin (Min) (V) | 3.65 |
Vout (Max) (V) | 5 |
Vout (Min) (V) | 3.3 |
Fixed output options (V) | 3.3, 5 |
Iq (Typ) (mA) | 4.5 |
Thermal resistance θJA (°C/W) | 156 |
Rating | Automotive |
Load capacitance (Min) (μF) | 10 |
Regulated outputs (#) | 1 |
Accuracy (%) | 3 |
PSRR @ 100 KHz (dB) | 37 |
Dropout voltage (Vdo) (Typ) (mV) | 250 |
Operating temperature range (C) | -40 to 125 |
- AEC-Q100 Grade1 Qualified (-40°C to +125°C)
- Available with 5.0V or 3.3V Output Voltage
- Ultra Low Ground Pin Current, 25 μA Typical for 100 μA Load
- VOUT Initial Accuracy of ±1.5%
- VOUT Accurate to ±3% Over Load and Temperature Conditions
- Low Dropout Voltage, 200 mV Typical with 150mA Load
- Low Off State Ground Pin Current for LM9076QBMA
- Delayed RESET Output Pin for Low VOUT Detection
- +70V/-50V Voltage Transients
- Operational VIN up to +40V
All trademarks are the property of their respective owners.
The LM9076Q is a ±3%, 150 mA logic controlled voltage regulator. The regulator features an active low delayed reset output flag which can be used to reset a microprocessor system at turn-ON and in the event that the regulator output voltage falls below a minimum value. An external capacitor programs a delay time interval before the reset output pin can return high.
Designed for automotive and industrial applications, the LM9076Q contains a variety of protection features such as thermal shutdown, input transient protection and a wide operating temperature range. The LM9076Q uses an PNP pass transistor which allows low drop-out voltage operation.
