1 / 2
公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  207粉丝
--- 产品详情 ---
汽车类 50mA、电池供电运行 (40V)、低 IQ、低压降稳压器
Output options Fixed Output
Iout (Max) (A) 0.05
Vin (Max) (V) 40
Vin (Min) (V) 4
Vout (Max) (V) 5
Vout (Min) (V) 3.3
Fixed output options (V) 3.3, 5
Iq (Typ) (mA) 0.02
Thermal resistance θJA (°C/W) 140
Rating Automotive
Load capacitance (Min) (μF) 22
Regulated outputs (#) 1
Accuracy (%) 3
Dropout voltage (Vdo) (Typ) (mV) 200
Operating temperature range (C) -40 to 125
  • AEC-Q100 Grade 1 Qualified (-40°C to 125°C)
  • Ultra Low Ground Pin Current (IGND ≤ 25μA for IOUT =0.1mA)
  • Fixed 5V, 3.3V, 50mA Output
  • Output Tolerance ±5% Over Line, Load, and Temperature
  • Dropout Voltage Typically 200mV @ IOUT = 50mA
  • ?45V Reverse Transient Protection
  • Internal Short Circuit Current Limit
  • Internal Thermal Shutdown Protection
  • 40V Operating Voltage Limit
All trademarks are the property of their respective owners.
The LM9036Q ultra-low quiescent current regulator features low dropout voltage and low current in the standby mode. With less than 25μA Ground Pin current at a 0.1mA load, the LM9036Q is ideally suited for automotive and other battery operated systems. The LM9036Q retains all of the features that are common to low dropout regulators including a low dropout PNP pass device, short circuit protection, reverse battery protection, and thermal shutdown. The LM9036Q has a 40V maximum operating voltage limit, a ?40°C to +125°C operating temperature range, and ±5% output voltage tolerance over the entire output current, input voltage, and temperature range.
