Output options | Adjustable Output |
Iout (Max) (A) | 1.5 |
Vin (Max) (V) | 20 |
Vin (Min) (V) | 2.1 |
Vout (Max) (V) | 20 |
Vout (Min) (V) | 1.2 |
Noise (uVrms) | 40 |
Iq (Typ) (mA) | 1 |
Thermal resistance θJA (°C/W) | 23 |
Rating | Automotive |
Load capacitance (Min) (μF) | 10 |
Regulated outputs (#) | 1 |
Features | Enable, Reverse current protection, Reverse voltage protection |
Accuracy (%) | 4 |
PSRR @ 100 KHz (dB) | 45 |
Dropout voltage (Vdo) (Typ) (mV) | 340 |
Operating temperature range (C) | -40 to 125 |
- Qualified for Automotive Applications
- AEC-Q100 Test Guidance With the Following:
- Device Temperature Grade 1: –40°C to 125°C Ambient Operating Temperature
- Device HBM ESD Classification Level 2
- Device CDM ESD Classification Level C6
- Optimized for Fast Transient Response
- Output Current: 1.5 A
- Dropout Voltage: 340 mV
- Low Noise: 40 μVRMS (10 Hz to 100 kHz)
- 1-mA Quiescent Current
- No Protection Diodes Required
- Controlled Quiescent Current in Dropout
- Fixed Output Voltages: 1.5V, 1.8V, 2.5V, and3.3V
- Adjustable Output Voltage: 1.21 V to 20 V
- Less Than 1-μA Quiescent Current in Shutdown
- Stable With 10-μF Output Capacitor
- Stable With Ceramic Capacitors
- Reverse-Battery Protection
- No Reverse Current
- Thermal Limiting
The TL1963A-Q1 device is a low-dropout (LDO) regulator optimized for fast transient response. The device can supply 1.5A of output current with a dropout voltage of 340mV. Operating quiescent current is 1mA, dropping to less than 1μA in shutdown. Quiescent current is well controlled; it does not rise in dropout as it does with many other regulators. In addition to fast transient response, the TL1963A-Q1 regulators have very low output noise, which makes them ideal for sensitive RF supply applications.
Output voltage range is from 1.21V to 20V. The TL1963A-Q1 regulators are stable with output capacitors as low as 10μF. Small ceramic capacitors can be used without the necessary addition of ESR, as is common with other regulators. Internal protection circuitry includes reverse-battery protection, current limiting, thermal limiting, and reverse-current protection. The devices are available in fixed output voltages of 1.5V, 1.8V, 2.5V, and 3.3V, and as an adjustable device with a 1.21-V reference voltage. The TL1963A-Q1 regulators are available in the 5-pin TO-263 (KTT) package.
