公司logo
华秋商城
1.8w內容 |  99w+浏览量  |  188粉丝
--- 产品详情 ---
具有电源正常指示功能的汽车类 500mA、低输入电压 (0.8V)、可调节超低压降稳压器
Output options Adjustable Output
Iout (Max) (A) 0.5
Vin (Max) (V) 5.5
Vin (Min) (V) 0.8
Vout (Max) (V) 3.6
Vout (Min) (V) 0.8
Noise (uVrms) 20
Iq (Typ) (mA) 1
Thermal resistance θJA (°C/W) 50
TI functional safety category Functional Safety-Capable
Rating Automotive
Load capacitance (Min) (μF) 2.2
Regulated outputs (#) 1
Features Enable, Power good, Soft start
Accuracy (%) 2
PSRR @ 100 KHz (dB) 27
Dropout voltage (Vdo) (Typ) (mV) 50
Operating temperature range (C) -40 to 125
  • Qualified for Automotive Applications
  • AEC-Q100 Test Guidance With the Following:
    • Device Temperature Grade 1: –40°C to 125°C
    • Device HBM ESD Classification Level 2
    • Device CDM ESD Classification C4A
  • VOUT Range: 0.8 V to 3.6 V
  • Ultra-Low VIN Range: 0.8 V to 5.5 V
  • VBIAS Range: 2.7 V to 5.5 V
  • Low Dropout: 50 mV Typical at 500 mA, VBIAS = 5 V
  • Power Good (PG) Output Allows Supply Monitoring or Provides a Sequencing Signal for Other Supplies
  • 2% Accuracy Over Line, Load, and Temperature
  • Programmable Soft Start Provides Linear Voltage Start-Up
  • VBIAS Permits Low VIN Operation With Good Transient Response
  • Stable With Any Output Capacitor ≥ 2.2 μF
  • Available in a Small 3-mm × 3-mm × 1-mm 10-Pin VSON Package
The TPS74701-Q1 low-dropout (LDO) linear regulator provides an easy-to-use, robust power management solution for a wide variety of applications. User-programmable soft start minimizes stress on the input power source by reducing capacitive inrush current on start-up. The soft start is monotonic and well-suited for powering many different types of processors and ASICs. The enable input and power good output allow easy sequencing with external regulators. This complete flexibility permits the user to configure a solution that meets the sequencing requirements of FPGAs, DSPs, and other applications with special start-up requirements.
A precision reference and error amplifier deliver 2% accuracy over load, line, temperature, and process. The device is stable with any type of capacitor greater than or equal to 2.2 μF, and is fully specified from –40°C to 125°C. The TPS74701-Q1 is offered in a small 3-mm × 3-mm 10-pin VSON package for compatibility with the TPS74801-Q1.
